94 Miata Parts
Go down
94 Miata Parts
Post  donoscituate on Mon Oct 11, 2010 9:54 pm
Anything not listed email me, this was a complete car
dovanss@netzero.comMiata parts 89-97 update 10/29/10
Engine, tranny, diff sold, car is coming apart, this was a complete running car
AC setup, Condenser, dryer, no compressor, worked fine $60
Radiator and fans, no leaks, 3 years old $75
Window washer & pump for ABS car, mounts in driver side wheel well $15
ABS pump and setup works fine $60
Drive side complete headlight assembly, motor, work perfectly, cover black $60
Passenger side door, manual window, complete, black, including electric mirror, door card in good shape no rust $70
Rear tail lights & license plate lights $80 for the 4 pieces
Hood, black, steel, $60
Trunk lid, black, with aftermarket rear spoiler $100
Soft top boot cover TAN, hardly used, $75
Interior parts, BLACK, glove box, passenger air bag, center console, instrument pod, rugs, heat/ac control $100
Steering column and key, steering wheel & headlight & wiper stalks. airbag $90
2 seats, driver side has typical light wear on side bolster, passenger fine, $80 for pair
Brake Master cylinder and booster & Clutch master cylinder $60
Power steering rack with plumbing(except pump) no leaks $60
Set of 4 stock alloy Daisy 14 rims (4) with 3 good Falken Anzisi tires195/60/14 $100 (4th has sidewall puncture)
Set of 4 OEM 6 spoke hollow 14x6 with 185-60-14 good tires $150
2 stock shocks, front, provided a smooth and stable ride, with springs & tops, $40 for both
Wiper motor and assembly $40
Heater core and blower assembly $40
2 Black side view Power mirrors, driver & passenger $60 for the pair
In tank Fuel pump & bigger 94 gas tank, $50
93 coil pack $50, different from 94 and later
Battery and hold down assembly, no rust $40
94 shell with good/legal MA title $50
Last edited by donoscituate on Fri Oct 29, 2010 6:55 pm; edited 1 time in total (Reason for editing : update list)
donoscituate
View user profile
Back to top Go down
Back to top
Permissions in this forum:
