1995 - Supercharged Miata For Sale - Autocross / Track Setup
Go down
Post  baltruckij on Fri Sep 27, 2013 4:43 pm
Low miles 76K - 1995 1.8L - montego blue paint silver wheels
Photos  - when i can post a link - till then email me
Car was setup for autocross and track days - I have had a blast with it at devens for SVTOA / SCCA ETC events so you may have seen it before.
Jackson racing supercharger
high boost pulley 8-10psi
Jackson racing Power card fuel controller - adds fuel with boost
BIPES - timing retard box - pulls timing vs boost to prevent knock and maximize average timing. Can adjust for race gas as available. Comes with instruction manual.
air/water intercooler setup with fans monster water/air cores - great for autox   - Short plumbing with great throttle response
Limited slip torsen rear differential
bilstein coilovers - 600F 325 Rear wide range of height adjustment
Adjustable sway bars - front and rear with adjustable end links
eccentric delrin bushings up front for 1.5 - 4 degrees negative camber
Mazdacomp Motor Mounts
Redline synthetic fluid trans and differential - Mobil 1 engine
Car was aligned with 50/50 cross weight with 170 lb driver
steel braided brake lines
hawk HP+ pads fresh - comes with a new set in box as well great auto-x or track pads
TR racing wheels with 75% toyo RA1's - 2 track days on these no autocross
Track ready with harddog roll bar installed - harness and diagonal bracing
Sparco racing seats + 5 point harness for passenger + drivers side - low mounted
Car has power steering good for for auto-x
Custom hood vents for cooling + dual electric fan upgrades
large PWR aluminum radiator for track use
water injection - progressive controller - pre supercharger
Aftermarket header - unknown brand
Exhaust has OEM cat - passes emissions
Relatively quiet aftermarket exhaust - passes limerock 86 DB sound limit
Aftermarket clutch installed
5 speed transmission recently replaced - Shifts great all gears
Brass aftermarket shifter bushing installed for tight shifting
New timing belt and water pump at 65K miles
well maintained - good bushings - fresh control arms up front with new ball joints and delrin inner bushings.
repacked front hubs in great shape.
Boost and AFR gauge installed
CD player
Asking $8K as is - this is a turn key fast auto-x car. I am selling because I need to cut back on my toys. I may remove some parts to lower price just let me know what you don't want and we can make a deal. I have original seats if desired, + a new soft top. Build cost is well over 11K and the parts are pretty fresh low miles - never winter driven - trailer queen the last couple years. I would like this to go to a good home with an autocrosser instead of a street car. Wheels and tires are over a grand.
I also have a set of 15x8 949 racing 6UL wheels I can cut a deal on if interested - also listed on this site for $450.
I just had to register it to clean the title up - will have a fresh title in 3 weeks.
if interested e-mail   baltrucki AT netscape.net      car is in manchester CT
baltruckij
View user profile
Back to top Go down
Back to top
Permissions in this forum:
